DISABLE INTRA-VLAN ROUTING FOR SPECIFIC HOSTS
Jesutofunmi O
Hello Guys,
I have a VLAN with over 200 hosts. I am trying to separate about 6 different hosts from the rest of the hosts in the same VLAN. I want host 1,2,3,4,5 and 6 to be able to communicate with each other but all other hosts from 7 to 200 to NOT be able to communicate with hosts 1,2,3,4,5 and 6.
My Topology is such as:
Core Switch--->Access Switches
Core Switch handles all the routing, VLAN creation, DHCP E.T.C
Please help!!!
balaji.bandi
in that case you need to create VLAN ACL - is that something your device should support.
example :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/vacl.html
BB
balaji.bandi
example :
BB
