Does Catalyst 9300 includes network essential base license once smart licensing is enabled?
Herman2018
Level 3
Level 3
Hi, I saw one catalyst 9300 switch the license status like below:
    smart licensing is enabled, but the device is not registered and eva license for DNA and network adv are already expired. but the switch works as normal.
anyone can please help explain the meaning of the license? does the switch default include the "network essential" base license when purchase the switch? And why the status is smart licensing is enabled but the device is not registered? please advise, thanks.
You do not like any support from Csico for any further issue.
for basic feature you should be fine, but for the basic feature if you purchased - it good to register with Cisco smartnet for perpetual permannet License.
BB
6 Replies 6
balaji.bandi
yes if the device not contacting smart license server, you have base license still runs.
if you have only base license you do not need to worry, but if you have advanced license then some features stop working ?
to understand better post show version
we have observed to even though license expires still works.
BB
Thanks @balaji.bandi . please see the output of sh ver below.
9300#sh ver
Cisco IOS XE Software, Version 16.09.03
Cisco IOS Software [Fuji], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.9.3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Wed 20-Mar-19 08:02 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2019 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 16.10.1r[FC1], RELEASE SOFTWARE (P)
9300 uptime is 1 year, 1 week, 2 days, 7 hours, 27 minutes
Uptime for this control processor is 1 year, 1 week, 2 days, 7 hours, 29 minutes
System returned to ROM by PowerOn at 11:57:01 SGT Fri Jun 21 2019
System restarted at 14:10:15 SGT Sat Aug 10 2019
System image file is "flash:cat9k_iosxe.16.09.03.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-advantage Smart License network-advantage
dna-advantage Subscription Smart License dna-advantage
Smart Licensing Status: UNREGISTERED/EVAL EXPIRED
cisco C9300-48P (X86) processor with 1419496K/6147K bytes of memory.
Processor board ID xxxxxxx
2 Virtual Ethernet interfaces
260 Gigabit Ethernet interfaces
40 Ten Gigabit Ethernet interfaces
10 TwentyFive Gigabit Ethernet interfaces
10 Forty Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
1638400K bytes of Crash Files at crashinfo:.
1638400K bytes of Crash Files at crashinfo-2:.
1638400K bytes of Crash Files at crashinfo-3:.
1638400K bytes of Crash Files at crashinfo-4:.
1638400K bytes of Crash Files at crashinfo-5:.
11264000K bytes of Flash at flash:.
11264000K bytes of Flash at flash-2:.
11264000K bytes of Flash at flash-3:.
11264000K bytes of Flash at flash-4:.
11264000K bytes of Flash at flash-5:.
0K bytes of WebUI ODM Files at webui:.
Thanks @balaji.bandi . Below is the license info. Please advise, thanks.
Questions :
1. Do you have License for Network-Advantage ?
2. if so please re-register with smat License get new features.
( for your Luck it was not working, if any enforcement done, your network will be down or malfunction due to features)
so register now or soon. (switch required internet connection to get Licensed) - there is also offline server available free from Cisco if you have thousands of devices in the network.
if this is only device then do it using cisco smart license.
BB
A: we don't have the license for Network-advantage. We just need basic feature-- layer 2 + static route (layer 3). So even not register for smart license, won't it be any issue, right?
BB
