Disabling 3des-cbc for SSH
ER2022
Frequent Visitor
Frequent Visitor
I would like to remove 3des-cbc for SSH as this was identified as deprecated ssh cryptographic settings.
does this mean if you disable 3des-cbc all the aes-cbc mode will be disable right?
And what is the impact on the switch operation?
3des-cbc Three-key 3DES in CBC mode
aes128-cbc AES with 128-bit key in CBC mode
aes128-ctr AES with 128-bit key in CTR mode
aes192-cbc AES with 192-bit key in CBC mode
aes192-ctr AES with 192-bit key in CTR mode
aes256-cbc AES with 256-bit key in CBC mode
aes256-ctr AES with 256-bit key in CTR mode
Thank you in advance,
Elmani
balaji.bandi
You can make custom as mentioned below : (to mitigate the issue)  - make sure you running  SSHv2
https://community.cisco.com/t5/security-documents/guide-to-better-ssh-security/ta-p/3133344
Note : this suggestion based on the information, if this is not meet the requirement, provide what is the device and IOS coder running, along with show ip ssh output.
BB
Thanks BB,
The target switch(WS-C3850-48P) is running on 03.03.01SE
and ip ssh output:
SSH Enabled - version 2.0
Authentication methods:publickey,keyboard-interactive,password
Encryption Algorithms:aes128-ctr,aes192-ctr,aes256-ctr,aes128-cbc,3des-cbc,aes192-cbc,aes256-cbc
MAC Algorithms:hmac-sha1,hmac-sha1-96
Authentication timeout: 60 secs; Authentication retries: 2
Minimum expected Diffie Hellman key size : 1024 bits
The cipher for SSH is already existing as above, now if I remove 3des-cbc, this mean all aes-cbc will be remove as well?
and what is the impact on the switch operation?
           >...The cipher for SSH is already existing as above, now if I remove 3des-cbc, this mean all aes-cbc will be remove as well?
 - You can verify this , for instance , with :
nmap --script ssh2-enum-algos ciscodevicename
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
