distance commands parameter
zeeshanr202
hi every body
i have a question regarding " distance"
command. here is the sample configuration
router ospf 1
network 10.0.0.0
distance 145 10.10.10.1 0.0.0.255 3
access-list 3 permit 2.0.0.0
in the above configuration " 10.10.10.1"
is router id supplying the routing information or the ip address of an interface supplying the information?
thanks
royalblues
Level 10
Level 10
For OSPF, the IP address and address mask entered for the distance command should match the source address and address mask of the OSPF router that sent the link-state advertisement (LSA).
The OSPF router would be the router ID
Narayan
royalblues
Level 10
Level 10
Narayan
