10-23-2024 11:53 AM
Good afternoon,
I have a Cisco 9300 switch running iOS cat9k_iosxe.17.15.01.SPA.bin, does anyone know if it support NHRP configuration?
10-23-2024 12:11 PM - edited 10-23-2024 12:13 PM
I think answer is NO - this only support GRE, may be you need to look for Router which can support these features.
If you looking tunnel look at the latest configuration guide :
10-23-2024 12:14 PM - edited 10-23-2024 12:17 PM
It does support but with restriction as you can see here.
On Cisco Catalyst 9300 Series Switches, hardware assisted IPsec is not supported. Use VXLAN instead.
On Cisco Catalyst 9300X Series Switches, Dynamic Multipoint Virtual Private Network (DMVPN) or NHRP with IPsec and FlexVPN are not supported. Use VXLAN or IPsec static virtual tunnel interface (SVTI) instead.
10-24-2024 04:09 AM
I have a cisco 9300 with iOS version 17,09,04a the support IP NHRP. I was curious about the other version since it is the latest version.
10-24-2024 04:16 AM
did you want to confirm if the next versions will support NHRP?
10-24-2024 04:21 AM
What is the next version?
