Does cat65 support two different power unit?
jason_majie
Level 2
Level 2
is it possible cat65 run on two different power units?
for example: one 2500w, one 3000w.
redundant mode.
Jon Marshall
redundant mode.
Jason in redudant mode no - from the 6500 12.2SXH and later config guide -
In systems with redundant power supplies, both power supplies must be of the same wattage. The Catalyst 6500 series switches allow you to use both AC-input and DC-input power supplies in the same chassis. For detailed information on supported power supply configurations, see the Catalyst 6500 Series Switch Installation Guide.
full link -
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/pwr_envr.html
Jon
yembasheerahamed
Community Member
The Catalyst 6500/6000 series switches allow you to mix AC-input and DC-input power supplies in the same chassis.
The system does not allow you to operate a power supply of different wattage even if the wattage is higher than the installed supply. The inserted supply shuts down.
The system does not allow you to have power supplies of different wattage installed in a redundant configuration. The lower wattage supply shuts down.
Check the following links also:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/pwr_envr.html
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfa8.shtml
I hope it would help you.
MB.Ahamed
jason_majie
Level 2
Level 2
Hi All:
we just tried one 1300w + one 3000w, both power units work fine in a single chassis.
Are they in redundant mode or combined mode ?
