Does factory reset affect Openflow virtual services?
nttuan
Visitor
Hi all,
I installed the Openflow Plugin on a Cisco 3650 switches, and recently have to do a factory reset. Now I can tab commands for openflow, running them in config terminal without a single error, but when I check the plugin using "show openflow <anything>" command It returned "No Application openflow Connected".
I checked the flash using "show flash:" and see "onep/apps-cli/openflow_2.2.xsd".
Does factory reset the switch had wiped the openflow plugin? What can I do to make it works again?
Seb Rupik
Hi there,
At the very least you will need to activate the virtual service in the running config:
virtual-service OPENFLOW_AGENT
  activate
If that fails, I assume the openflow OVA is still on the flash. In which case just install it again:
virtual-service install name OPENFLOW_AGENT package flash: <openflowxxxx.ova>
cheers,
Seb.
Seb Rupik
Hi there,
  activate
cheers,
Seb.
Yep, the virtual-service command verify that the service was just deactivated and still in system. A simply activate command made it work. Thank you very much.
