Dot1X AAA issue
abdulwadood
%DOT1X-5-FAIL: Switch 1 R0/0: sessmgrd: Authentication failed for client (0076.861a.2790) with reason (AAA Server Down) on Interface Gi1/0/17 AuditSessionID 099FA8C00000001E973BE640 Username: CP-7821-SEP0076861A2790
May 20 18:21:18.739: %DOT1X-5-RESULT_OVERRIDE: Switch 1 R0/0: sessmgrd: Authentication result overridden for client (0076.861a.2790) on Interface Gi1/0/17 AuditSessionID 099FA8C00000001E973BE640
I have configured clear pass when i configure AAA Configuration on this switch i face an error above details could someone help me on this whats the issue.
7 Replies 7
specify the interface use as source to connect to AAA and issue will solved
ip radius source-interface <>
MHM
balaji.bandi
what is the model of the switch and IOS running, what configuration done on the switch ?
what is the port configuration also on G1/0/17 - what end device connected to that port ?
is this AAA worked before is new setup ?
also check the does the switch can reach you clear pass server.
BB
Please find the configuration
we do not see yet or missed to attach the confg here ?
BB
abdulwadood
This is the issue we face once we connect with Newly Cisco IP PHone
Clearpass receive both authentication MAC as well as 802.1X authentication but we want only mac authentication why this phone send both authentication how do i stop this
Can you share config
MHM
abdulwadood
TestSw#sh running-config
Building configuration...
Current configuration : 15982 bytes
! Last configuration change at 19:51:36 UTC Mon May 20 2024 by admin
version 17.6
service call-home
platform punt-keepalive disable-kernel-core
hostname TestSw
vrf definition Mgmt-vrf
**bleep**-family ipv4
exit-**bleep**-family
**bleep**-family ipv6
enable secret xxxxxxxx
aaa new-model
aaa group server radius GR
server name GR-NAC
aaa authentication dot1x default group GR
aaa authorization network default group GR
aaa accounting update periodic 5
aaa accounting dot1x default start-stop group GR
aaa accounting system default start-stop group GR
aaa server radius dynamic-author
client 192.168.40.21 server-key xxxxxxxx
aaa session-id common
switch 1 provision c9300-48p
ip routing
ip dhcp snooping
login on-success log
device-sensor accounting
device-sensor notify all-changes
crypto pki trustpoint TP-self-signed-1514558421
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1514558421
revocation-check none
rsakeypair TP-self-signed-1514558421
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
quit
dot1x system-auth-control
license boot level network-essentials addon dna-essentials
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
memory free low-watermark processor 131688
redundancy
mode sso
crypto engine compliance shield disable
transceiver type all
monitoring
class-map match-any system-cpp-police-ewlc-control
description EWLC Control
class-map match-any system-cpp-police-topology-control
description Topology control
class-map match-any system-cpp-police-sw-forward
description Sw forwarding, L2 LVX data packets, LOGGING, Transit Traffic
class-map match-any system-cpp-default
description EWLC Data, Inter FED Traffic
class-map match-any system-cpp-police-sys-data
description Openflow, Exception, EGR Exception, NFL Sampled Data, RPF Failed
class-map match-any system-cpp-police-punt-webauth
description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
description L2 LVX control packets
class-map match-any system-cpp-police-forus
description Forus **bleep** resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
description MCAST END STATION
class-map match-any system-cpp-police-high-rate-app
description High Rate Applications
description MCAST Data
class-map match-any system-cpp-police-l2-control
description L2 control
class-map match-any system-cpp-police-dot1x-auth
description DOT1X Auth
class-map match-any system-cpp-police-data
description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
description Stackwise Virtual OOB
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
description DHCP snooping
class-map match-any system-cpp-police-ios-routing
description L2 control, Topology control, Routing control, Low Latency
class-map match-any system-cpp-police-system-critical
description System Critical and Gold Pkt
class-map match-any system-cpp-police-ios-feature
description ICMPGEN,BROADCAST,ICMP,L2LVXCntrl,ProtoSnoop,PuntWebauth,MCASTData,Transit,DOT1XAuth,Swfwd,LOGGING,L2LVXData,ForusTraffic,ForusARP,McastEndStn,Openflow,Exception,EGRExcption,NflSampled,RpfFailed
policy-map system-cpp-policy
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip **bleep**
shutdown
negotiation auto
interface GigabitEthernet1/0/1
switchport access vlan 150
spanning-tree portfast
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
switchport trunk native vlan 150
switchport mode access
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
switchport access vlan 40
interface GigabitEthernet1/0/6
switchport voice vlan 65
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
switchport voice vlan dot1p
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
switchport mode trunk
interface GigabitEthernet1/0/48
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface TenGigabitEthernet1/1/5
switchport access vlan 10
interface TenGigabitEthernet1/1/6
interface TenGigabitEthernet1/1/7
interface TenGigabitEthernet1/1/8
interface FortyGigabitEthernet1/1/1
interface FortyGigabitEthernet1/1/2
interface TwentyFiveGigE1/1/1
interface TwentyFiveGigE1/1/2
interface AppGigabitEthernet1/0/1
interface Vlan1
no ip **bleep**
shutdown
interface Vlan10
ip **bleep** 10.10.10.1 255.255.255.0
interface Vlan40
ip **bleep** 192.168.40.19 255.255.255.0
interface Vlan65
ip **bleep** 192.168.65.19 255.255.255.0
interface Vlan150
ip **bleep** 192.168.150.251 255.255.255.0
interface Vlan151
ip **bleep** 192.168.151.19 255.255.255.0
interface Vlan152
ip **bleep** 192.168.152.19 255.255.255.0
interface Vlan160
ip **bleep** 192.168.160.2 255.255.255.0
interface Vlan190
ip **bleep** 192.168.190.1 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip radius source-interface Vlan40
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius server GR-NAC
**bleep** ipv4 192.168.40.21 auth-port 1812 acct-port 1813
timeout 2
retransmit 3
key xxxxxxxxx
control-plane
service-policy input system-cpp-policy
line con 0
transport preferred telnet
stopbits 1
line vty 0 4
transport input all
line vty 5 31
transport input all
