Dot1x Authetication between two cisco switch
SAM1275
We have two switches 2960X series and C1000 8 port series switch
C1000 port connect as dot1x supplicant to C2960X switch port act as authenticator
Dot1x authentication happening correctly and traffic also passing through. however on C1000 supplication port portocols stay down state. is it expected behavior and if show do have any document to address this.
5 Replies 5
balaji.bandi
how is your configuration looks like on both the switches.
Look some example guide how you can achieve this :
https://content.cisco.com/chapter.sjs?uri=%2Fsearchable%2Fchapter%2Fwww.cisco.com%2Fcontent%2Fen%2Fus%2Ftd%2Fdocs%2Fswitches%2Flan%2Fcatalyst4500%2FXE3-9-0E%2F15-25E%2Fconfiguration%2Fguide%2Fxe-390-configuration%2Fdot1x.html.xml#80573
BB
My question is simple why supplicant port protocol stay down(protocol down) even authentiation is success and traffic is passing through on supplicant port.
Check below
MHM
CISP (NEAT)
This need to config between two SW to make c1000 send mac to 2960 and 2960 auth host connect to c1000.
