Doubt about Stp
Dear Team,
Can u tell me about how to run STP  for preventing looping without blocking any port in a redundant network .
Eg. suppose we have five switches and these are connected like ring network..
it's question asked me in interview and  I told him that this is not possible..so please suggest me that is this possible if yes then could we do this.
On Juniper EX switches you can use virtual-chassis to turn upto 10 switches into a single logical switch.  All switches connect to each other in a ring topology. No blocked ports and no STP required.
I believe Cisco stackwise+ is a similar solution.
Also, you should be able to use vPC feature to achive the same with STP on.
Thanks.
6 Replies 6
mlund
Level 11
Level 11
I had also said it's not possible, unless you are using layer3 between the switches instead of layer2.
Because then you have spanning-tree running on each switch but not between the switches.
/Mikael
Thanks for reply but can u tell me how is this possible if we use layer 3 switch.
  If your connections between the switches are routed links then STP is irrelevant and is not run on those links .
rais
Level 11
Level 11
Is stacking an option?
Thanks.
Hi, He did not give me any option like Stacking. if we can do this using stacking than share answer... Thanks,
Thanks.
