DRAM slot usage on 1760
slaterc
I have a 1760 router with 96MB DRAM. Is there a way I can find out, without opening the router up, (1) how many slots there are for installing DRAM; and (2) which of the slots are occupied with DRAM and which are free?
spremkumar
Level 9
Level 9
You can have max of 128MB in both 1760 and 1760V models by default 1760V comes with 96MB.
I dont think its possible to view the DRAM slots or free slots available for use..
for more info do refer this link...
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a00800920f2.html
regds
Hi, thanks for your reply. I have already looked at that page. I was just wondering if I could upgrade the RAM without having to discard any SIMM/DIMM which is already present.
I guess I'm just going to have to get the screwdrivers out ;-)
