ds3 question
D0nprintup_2
Level 5
Level 5
I have a full ds3 going into a 2800 series router. We then connect into a pix for the firewall.
I need to know if there is away to dedicate roughly 5 megs to one person/ip address.
tdrais
Level 11
Level 11
If you apply something like the below on both ends of the ds3. You will need to reverse the access list so it matches correctly depending on if it is a source or a destination.
If you only need to reserve the traffic in a single direction you can not apply it to both sides.
Be aware if you are running a full rate ds3 (non ATM) card in a 2800 you may have issues running QoS and full line speed. Check your processor load after you attempt this to be sure.
class-map special-user
match access group name special-user
IP access extended special-user
permit ip host x.x.x.x any
Policy-map special-user
class special-user
bandwidth 5000
int sx.x.x
service-policy special-user output
