12-29-2006 07:26 AM - edited 03-05-2019 01:31 PM
We have a backup server on our network that has 5 available NICs. We are looking to see if we can get it teamed to where it can receive on all 5 NICs.
What class of switch would support this type of teaming or would it take a load balancer?
I know software teaming server side allows you to recieve on one, transmit on many. We are looking for the opposite of that.
Thanks.
Solved! Go to Solution.
12-29-2006 07:43 AM
802.3ad is your choice.
Some NIC cards also support Cisco proprietary Etherchannel.
Hope this helps.
Bill.
12-29-2006 07:43 AM
Hope this helps.
Bill.
12-29-2006 08:37 AM
Thanks Bill, that is exactly what I was looking for.
