dscp and diffserv
carl_townshend
Hi all, are these the same thing or different ? I was told they are the same.
srue
Level 7
Level 7
one way that diffserv is implemented is using dscp. there are other ways though - CoS, ToS, and Precedence.
Diffserv is a QoS technique which is configured on a per hop basis.
DSCP on the other hand is a 6 bit field used for classifying traffic and prioritising them. First three bits are the class selector bits and the next 3 bits are the drop precednce bits.
http://www.cisco.com/warp/public/105/dscpvalues.html
http://en.wikipedia.org/wiki/Differentiated_services
HTH, rate if it does
Narayan
