dscp and drop precedence
carl_townshend
hi all, I have been looking into dscp and drop precedence, is drop precedence just a feature of a dscp value or something totally different?
Pravin Phadte
Level 5
Level 5
It is the feature of the dscp value.
This can be mentioed as 1,2 etc or just droped. Depending on the class map defined the policy will work.
Also note that some old ios does not have the command drop.
Hope this helps
Pravin
can you explain a little more about this?
