DSCP Remark policed traffic in priority queue
mario.jost
Level 3
Level 3
I have following configuration on various C9200 & C9300 models with IOS-XE version 16.12.05b
table-map QOS_OUT
 map from  46 to 0
 default copy
policy-map QOS_LAN_OUT
 class QOS_VOICERTP_OUT
  priority level 1
  police cir 2952000 bc 7380
   conform-action transmit
   exceed-action set-dscp-transmit dscp table QOS_OUT
But when i want to add this configuration to a 3850 switch with the same IOS-XE version, i get following error:
SWITCH(config)#policy-map QOS_LAN_OUT
SWITCH(config-pmap)# class QOS_VOICERTP_OUT
SWITCH(config-pmap-c)#priority level 1
SWITCH(config-pmap-c)#police cir 2952000 bc 24600
SWITCH(config-pmap-c)#conform-action transmit
SWITCH(config-pmap-c-police)#exceed-action set-dscp-transmit 0
Nov 10 12:37:48.732: %FMANRP_QOS-3-MARKDOWNCHECK: Only markdown with a table-map is supported.
SWITCH(config-pmap-c-police)#exceed-action set-dscp-transmit dscp table QOS_OUT
Nov 10 12:42:09.130:  Table-map action not allowed in police used with priority feature
What am i missing here?
Mark Elsen
 - Check this thread :
            https://community.cisco.com/t5/switching/qos-configuration-table-map-catalyst-9200/td-p/4486924
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Joseph W. Doherty
"What am i missing here?"
That different switches (especially when different "generations") have different QoS feature support (because switch QoS is also tied to hardware capabilities).
@Mark Elsen has provided a nice reference to help you try to work out similar results.
