Dual isp
elite2010
Level 3
Level 3
Hi ,
If i have the following scenario  and ASA in active standby mode , will it work ? . How can i utilize both ISP ?
-----ASA1----Router  1 -----ISP1
-----ASA1----Router 2 -----isp2
Please help
6 Replies 6
togrul.azizli
Hi ,
Is it Failover or FHRP (HSRP) active standby ?
Now is HSRP .
Among HSRP,VRRP and GLBP only GLBP can be used as Active-Active so you can use both ISPs then configure GLBP instead of HSRP. So you can load-balance your inside traffic to go outside via two different ISPs .
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/ft_glbp.html
http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ip-services/product_data_sheet0900aecd803a546c.html
Hope it helps
Asa also should be active /active ?
You will configure GLBP as normal HSRP (I mean same idea , you give Virtual IP) and there is little bit difference in configuration , the difference between GLBP and other FHRP protocols is that the ASAs will be Active/Active. For inside devices the gateway will be Virtual IP that you gave ,like in HSRP but GLBP will load-balance your traffic .
You can see GLBP explained in youtube or cisco documentations.
Let me know if it helps
saif musa
Level 4
Level 4
