Dumb switch
wgranada1
Quick question I need a dumb switch to plug into my internet providers router.
Going to run that switch in a conference room so outside folks can reach the internet. I have a 2900 series switch and want to turn that into a dumb switch. Is all that is needed is to wipe the config by doing write erase and that is it?
Marvin Rhoads
In addition to erasing the running and saved IOS script, you may also want to erase the vlan.dat file in NVRAM. The commmand for that is "delete flash:vlan.dat". After both this and the "write erase" commands, you should perform a "reload".
See the detailed technote covering just this procedure at: http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800c4546.shtml#reset_switch
8 Replies 8
Collin Clark
That should do it. I would double check and make sure HTTP is disabled, VTY lines are off, etc. You might want to consider 'hardening' the switch as well.
ok sounds good, thank you for help. That sounded a little to easy but I appreciate your help!!!! thank you
Remember to issue #dir and see if it has vlan.dat file, then you should delete this file. This will ensure this dumb switch does not have any previos/old vtp domain/vlan info.
Hope this helps !!
Shaheen
Marvin Rhoads
Good catch thank you sir for that!!!
wgranada1
Thank you both for your response much appreciated!!!!!
Joseph W. Doherty
One other suggestion, if your 2900 series switch supports VTP, you may want to configure it to ignore VTP.
K will do thank you for that as well
