Edge switch inquiry
moamen1230
Frequent Visitor
Frequent Visitor
Hello Guys,
I have an issue and i need your help if possible.
I have 6 cisco Switches 2960 48 port and one 3750 core switch, one of the edge switches damaged i think the motherboard is corrupted.
Somehow i need to replace it with SG220-50-K9-EU  .. Is that possible ?
Thanks in advance
5 Replies 5
Mark Elsen
 - Depends on the needed capacities , check Table 1 from the document below :
           https://www.cisco.com/c/en/us/products/collateral/switches/small-business-220-series-smart-plus-switches/datasheet-c78-731284.html
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
I have already trying to connect the SG220-50-K9-EU to the core switch with the same needed setting different way as no vtp mode on this model.
but didn't work ... VLANs can't reach each other
core and new switch configuration attached.
Note: The two switches is connecting on port 48 on both, I disabled the ether channel till i solve this issue
Thank you
Hello
In don’t see any ether channel between those two switches?- try the following
core
configure the switchport connecting to the new switch as a trunk
int x/48
switchport mode trunk
new switch
Change spanning-mode to pvst
spanning-tree mode pvst
Kind Regards
Paul
i did the following:
On Core switch
interface GigabitEthernet7/0/48
New Switch:
No pvst mode
Third-F-Edge(config)#spanning-tree mode
mstp Configure IEEE 802.1S Multiple Spanning Tree Protocol
rstp Configure IEEE 802.1W Rapid Spanning Tree Protocol
stp Configure IEEE 802.1D Spanning Tree Protocol
Really appreciate your support
 - Ref : https://community.cisco.com/t5/small-business-support-documents/spanning-tree-inter-connect-with-catalyst/ta-p/3141994
   SMB switch default STP mode is RSTP, and supports MSTP. SMB does not support PVST+ or rapid-PVST+.
              It would seem advisable to keep your core and connected equipment homogeneous
 M.
