EEM to bounce ports
Adam-USA
I want to use EEM code to bounce ports of two switches, but the code I have bounce only the first switch ports.
event manager applet port_bounce authorization bypass
event none sync yes maxrun 240
action 0010 set switch "1"
action 0020 cli command "enable"
action 0030 cli command "config t"
action 0040 while switch le 2
action 0060  set port "1"
action 0070  if $port le "5"
action 0080   cli command "interface Gi$switch/0/$port"
action 0090   cli command "shutdown"
action 0100   wait 5
action 0110   cli command "no shutdown"
action 0120   increment port 1
action 0130  else
action 0135   increment switch 1
action 0140  end
action 0145 end
I appreciate any help!
Dan Frey
Place the "set port 1" outside the while loop.   port variable keeps getting set to 1 at each iteration.
Dan Frey
Adam-USA
Thank you Dan
