EIGRP Default Route
jeff.cook
Level 3
Level 3
If I want to pass a default route via EIGRP, so all routers will get a default, do I want to...
network 0.0.0.0 0.0.0.0
or
network 0.0.0.0 255.255.255.255
Or is there a better way?
Thank You
srue
Level 11
Level 11
assuming you have a default route defined already using the "ip route..." command, try "redistribute static".
DialerString_2
Level 6
Level 6
Try using the "ip default network" - If you want all router to use this router as the default out.
Edison Ortiz
I would say better way but different ways depending on the network or customer requirements.
The list can be found here:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094374.shtml
HTH,
__
Edison.
