EIGRP Issue
milkboy33
Level 4
Level 4
Hi All,
   Ok, we got two routers on a site to site VPN tunnel. Tunnel is up and EIGRP is talking. The problem is on Router B it's not getting the correct route(s). Take a look at the output below. Any help is greatly appreciated!
Router A
router eigrp 88
passive-interface FastEthernet0/0
passive-interface FastEthernet0/1
passive-interface FastEthernet0/0/0
network 3.3.3.0 0.0.0.3
network 10.125.177.0 0.0.0.255
no auto-summary
#sh ip route
     3.0.0.0/30 is subnetted, 1 subnets
C       3.3.3.0 is directly connected, Tunnel0
     65.0.0.0/27 is subnetted, 1 subnets
C       65.211.235.128 is directly connected, FastEthernet0/0/0
     10.0.0.0/24 is subnetted, 3 subnets
D       10.19.121.0 [90/26882560] via 3.3.3.2, 00:12:36, Tunnel0
S       10.25.178.0 [1/0] via 10.25.177.254
C       10.25.177.0 is directly connected, FastEthernet0/0
S*   0.0.0.0/0 [1/0] via 65.211.235.145
Router B
network 10.19.121.0 0.0.0.255
no auto-summary
#sh ip route
     64.0.0.0/29 is subnetted, 1 subnets
C       64.60.196.32 is directly connected, FastEthernet0/0/0
     10.0.0.0/24 is subnetted, 1 subnets
C       10.19.121.0 is directly connected, FastEthernet0/0
S*   0.0.0.0/0 [1/0] via 64.60.196.33
Notice on Router B we don't see an EIGRP route to Router A's internal subnet.... *confused....
Tom
Tom
I believe that your problem is a typo on router A. You have configured under router eigrp
this has an extra digit in the second octet that prevents it from matching the LAN address.
Rick
Rick
cadet alain
Could you post sh ip eigrp topology as well as sh run | s router eigrp on both routers.
Alain
Tom
Rick
Rick
Tom
According to the output of show ip route in your original post the network is
So the entry in EIGRP says the second octet is 125 and the show up route says the second octet is 25. That is what I mean that the second octet is wrong.
Rick
Rick
