eigrp one of subnet not updated
Arie
Can anyone explains me why R2 is not getting information from R1 about his inner subnet: 172.16.1.0?
R1 has in eigrp network classfull subnet added: 172.16.0.0 so 172.16.1.0 should be attached and R2 should receive it inside his routing table.
Funny thing is R2 has similar situation (also network 172.16.0.0 added) and R1 can see R2's 172.16.2.0
Topology:
Heres my configs:
R1
R1#sh run
Building configuration...
Current configuration : 717 bytes
version 12.2
hostname "R1"
ip subnet-zero
interface Ethernet0
ip address 192.168.10.5 255.255.255.252
half-duplex
no cdp enable
interface FastEthernet0
ip address 172.16.1.1 255.255.255.0
speed auto
no cdp enable
interface Serial0
ip address 172.16.3.1 255.255.255.252
clockrate 64000
no fair-queue
no cdp enable
interface Serial1
no ip address
shutdown
no cdp enable
router eigrp 1
network 172.16.0.0
network 192.168.10.4 0.0.0.3
no auto-summary
ip classless
no ip http server
no cdp run
line con 0
line aux 0
line vty 0 4
login
no scheduler allocate
end
R1#
R2
R2#sh run
Current configuration : 759 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
interface FastEthernet0/0
ip address 172.16.2.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0
ip address 172.16.3.2 255.255.255.252
interface Serial0/1/1
ip address 192.168.10.9 255.255.255.252
clock rate 64000
router eigrp 1
network 172.16.0.0
no auto-summary
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
37 Replies 37
ok please keep me posted.
Thank you in advance.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
see above:
R1(config)#int loopback 100
R1(config-if)#ip address 172.16.1.1 255.255.255.0
% 172.16.1.0 overlaps with FastEthernet0
R1(config-if)#ip address 172.16.1.2 255.255.255.0
R1(config-if)#
yeap, you must first remove the ip 172.16.1.1 under the interface Fast0
interface FastEthernet 0
no ip add 172.16.1.1 255.255.255.0
then
Interface loopback0
added, now i see on R2's routing table 172.16.1.1 appears
192.168.10.0/30 is subnetted, 2 subnets
D 192.168.10.4 [90/2195456] via 172.16.3.1, 01:20:03, Serial0/1/0
C 192.168.10.8 is directly connected, Serial0/1/1
172.16.0.0/16 is variably subnetted, 3 subnets, 2 masks
D 172.16.1.0/24 [90/2297856] via 172.16.3.1, 00:00:48, Serial0/1/0
C 172.16.2.0/24 is directly connected, FastEthernet0/0
C 172.16.3.0/30 is directly connected, Serial0/1/0
Whats wrong with previous configuration then?
Great,
The interface Fa0 should have communication with the other end, so try to connect a computer to the port FastEthernet 0 using a crossover cable. Test the connectivity with a ping from the PC to the ip 172.16.1.1
And assign to the computer the IP 172.16.1.2 255.255.255.0
Also please remove the loopback created previously.
In a real environment if there is nothing connected to the port, the subnet will not be advertised by the routing protocol.
Will check give me a moment.
Note that behind 172.16.2.0 there is also nothing but subnet is broadcasted correctly.
yeap that is weird, but now we can try connecting the computer.
i defined for PC:
IP: 172.16.1.2 /24
GW: 172.16.1.1 /24
Ping result:
Destination host unreachable
Request timed out
Request timed out
Request timed out
Any other idea what could be wrong here?
Is the FastEthernet 0 configured with the IP 172.16.1.1? but remember to remove the interface loopback created previously.
forgot to remove loopback - did and now pc can ping gw .1.
I checked whether am i able to ping 172.16.2.1 from PC - OK
and from R2 to ping PC - OK
seems to be working but have no idea why it happend.
no worries my friend, good to know we have ping between the devices.
Please verify the routing table in R2
routing table fine now :)
D 192.168.10.4 [90/2195456] via 172.16.3.1, 01:45:55, Serial0/1/0
D 172.16.1.0/24 [90/2172416] via 172.16.3.1, 00:04:06, Serial0/1/0
What was the problem ?:)
Great!
In real environment if the interface is not connected to other device it will be seen as down. So it probably was originated for the simulator.
So if the interface is down, the router will not advertise the subnet because it looks like inactive.
Note that interface was up. I am not working on simulator i have my real rack lab at home for CCNA, CCNP and CCIE (haha)
See here what you've fixed (screenshoot of my rack): https://1drv.ms/i/s!AqKrvcy76bbDhC9HvgGDVhRLf9kO
At the bottom starts with Cisco 1700 (our R1) - maybe because it's old :D ?
Next up is Cisco 1841 (R2), and then Cisco 2801 (R3) (which i use for Voice in future)
Now i think that we could check also topology and topology all-links (R2), Maybe there was entry for but somehow EIGRP was treaded it as FS, what do you think could it be possible? But that's just a shoot...
heyy very good!!! which model of routers are you using? R2 should have as best path to R1 to reach the subnet 172.16.1.0/24 unless this subnet is configured on other device or metrics like bandwidth or delay were modified but your config does not show that.
