eigrp one of subnet not updated
Arie
Can anyone explains me why R2 is not getting information from R1 about his inner subnet: 172.16.1.0?
R1 has in eigrp network classfull subnet added: 172.16.0.0 so 172.16.1.0 should be attached and R2 should receive it inside his routing table.
Funny thing is R2 has similar situation (also network 172.16.0.0 added) and R1 can see R2's 172.16.2.0
Topology:
Heres my configs:
R1
R1#sh run
Building configuration...
Current configuration : 717 bytes
version 12.2
hostname "R1"
ip subnet-zero
interface Ethernet0
ip address 192.168.10.5 255.255.255.252
half-duplex
no cdp enable
interface FastEthernet0
ip address 172.16.1.1 255.255.255.0
speed auto
no cdp enable
interface Serial0
ip address 172.16.3.1 255.255.255.252
clockrate 64000
no fair-queue
no cdp enable
interface Serial1
no ip address
shutdown
no cdp enable
router eigrp 1
network 172.16.0.0
network 192.168.10.4 0.0.0.3
no auto-summary
ip classless
no ip http server
no cdp run
line con 0
line aux 0
line vty 0 4
login
no scheduler allocate
end
R1#
R2
R2#sh run
Current configuration : 759 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
interface FastEthernet0/0
ip address 172.16.2.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0
ip address 172.16.3.2 255.255.255.252
interface Serial0/1/1
ip address 192.168.10.9 255.255.255.252
clock rate 64000
router eigrp 1
network 172.16.0.0
no auto-summary
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Great,
The interface Fa0 should have communication with the other end, so try to connect a computer to the port FastEthernet 0 using a crossover cable. Test the connectivity with a ping from the PC to the ip 172.16.1.1
And assign to the computer the IP 172.16.1.2 255.255.255.0
Also please remove the loopback created previously.
In a real environment if there is nothing connected to the port, the subnet will not be advertised by the routing protocol.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
37 Replies 37
Julio E. Moisa
The serial interface on R2 is not on the same segment that the serial interface in R1.
@Julio: they are both in same subnet. Or i dont get it.
R1  routing table: (all subnets correctly added)
R1#show ip route
192.168.10.0/30 is subnetted, 1 subnets
C 192.168.10.4 is directly connected, Ethernet0
172.16.0.0/16 is variably subnetted, 3 subnets, 2 masks
C 172.16.1.0/24 is directly connected, FastEthernet0
D 172.16.2.0/24 [90/2172416] via 172.16.3.2, 00:33:10, Serial0
C 172.16.3.0/30 is directly connected, Serial0
R2  routing table:
192.168.10.0/30 is subnetted, 2 subnets
D 192.168.10.4 [90/2195456] via 172.16.3.1, 00:41:40, Serial0/1/0
C 192.168.10.8 is directly connected, Serial0/1/1
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.16.2.0/24 is directly connected, FastEthernet0/0
C 172.16.3.0/30 is directly connected, Serial0/1/0
Hi Arie
R1
interface Serial0
clockrate 64000
no fair-queue
no cdp enable
R2
interface Serial0/3/0
no ip address
shutdown
clock rate 2000000
interface Serial0/3/1
ip address 192.168.10.10 255.255.255.252
If one of these interface is connected to R1, it should be on the same subnet that R1 or vice versa R1 should be on the same subnet of R2. And this subnet must be advertised under the EIGRP process.
SORRY ! I provided config from R3 (other router) as R2 - now i placed correct config for R2 can you check again?
No worries,
The R2's routing table is receiving the subnet 192.168.10.4. It looks be fine.
Try to execute these lines on R2
show ip route 192.168.10.5 and  show ip route 172.16.1.1
R2#show ip route 192.168.10.5
Routing entry for 192.168.10.4/30
Known via "eigrp 1", distance 90, metric 2195456, type internal
Redistributing via eigrp 1
Last update from 172.16.3.1 on Serial0/1/0, 00:51:00 ago
Routing Descriptor Blocks:
* 172.16.3.1, from 172.16.3.1, 00:51:00 ago, via Serial0/1/0
Route metric is 2195456, traffic share count is 1
Total delay is 21000 microseconds, minimum bandwidth is 1544 Kbit
Reliability 241/255, minimum MTU 1500 bytes
Loading 1/255, Hops 1
R2#show ip route 172.16.1.1
% Subnet not in table
R2#
Could you please execute this command on R1, i would like to see if the interface FastEthernet 0 is up otherwise R1 will not advertise it.
show ip interface brief.
it's up, i also checked before.
R1#show ip int br
FastEthernet0 172.16.1.1 YES NVRAM up up
Ethernet0 192.168.10.5 YES NVRAM up up
Serial0 172.16.3.1 YES NVRAM up up
Serial1 unassigned YES NVRAM administratively down down
Just for testing purpose, configure keepalive command line under the interface FastEthernet 0  and check again the routing table on R2
Are you able to ping the 172.16.1.1 from the PC?
If that does not work, we are going to remove the IP 172.16.1.1 under the FastEthernet0 and create a loopback on R1
example:
interface loopback 100
ip add 172.16.1.1 255.255.255.0
In order to discard any bug or problem between the PC and the FastEther0
i don't know this what is the full command Julio?
dont have the pc there, lets first try keepalive and the i create loopback (whats full command for keepalive)?
just keepalive.
keepalive
Keepalive command is used to send keepalive packets to the next router or device altough we dont have response from that. So the interface will look up any time.
no change after keepalive, trying with loopback...
