EIGRP OSPF redistribution
nuggetinu
Dennis Mink
check this post:
https://www.cisco.com/c/en/us/support/docs/ip/enhanced-interior-gateway-routing-protocol-eigrp/8606-redist.html
so yes its possible
Please remember to rate useful posts, by clicking on the stars below.
I meant the segment where both ospf area 0 and eigrp are running? is that even possible?
Julio E. Moisa
You can do that but I dont see the reason to implement redistribution between them on this segment. From my point of view you should use one of these routing protocols I dont see the reason to be executing both under the same link.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
