EIGRP resets
Ahmede
I have a 3550 switch connected to two 7206 routers. We are running EIGRP between the 3.. For some reason the EIGRP neighbors on the 3550 to the 7206 reset every 1:19 minutes. No errors on the interfaces.
Nov 24 11:31:46: %DUAL-5-NBRCHANGE: IP-EIGRP 1: Neighbor x.x.x.x (Vlan69) is down: retry limit exceeded
Nov 24 11:31:47: %DUAL-5-NBRCHANGE: IP-EIGRP 1: Neighbor x.x.x.x(Vlan69) is up: new adjacency
The neighbor between the two routers on the same VLAN is working fine. There another EIGRP neighbor on the 3550 to another switch and it's working fine as well..
The 7206 is connected to the 3550 via GIG interface, and Fast interface on the switches..
Here's teh config of one of the 7206 routers
interface GigabitEthernet0/2
description Link to
ip address x.x.x.x
no ip proxy-arp
duplex full
speed 100
media-type rj45
no negotiation auto
end
Here's te config of the switch port
interface FastEthernet0/47
description xxxxx
switchport access vlan 69
switchport mode dynamic desirable
speed 100
duplex full
end
Any help please..
Thanks..
vmoopeung
Level 5
Level 5
The message "retry limit exceeded" comes , because you are not able to ack or recieve upates and the updates are going to be sent for 16 times.At this point the neigh adjacency will be resseted.
Kindly check your ip addresss and the subnet masks
amit-singh
Level 8
Level 8
Try changing you switchport config like below:
description xxxxx
switchport mode acess
speed 100
duplex full
end
With switchport mode dynamic desirable switch port sends DTP frames out and try to setup trunk negotiation with the peer port. The port should be put on static mode access.
-amit singh
