a layer 2/layer 3 port on 3725
axfalk
we have a 3725, where we have a requirement to define one of the interfaces as both, layer 2 and layer 3. if we define that int as a switchport on a certain vlan and then define that vlan as a layer 3, would that work?
thanks...
Hi Friend,
Yeah you need to have switchport module for the same.
A configuration guide for switchport module
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t11/ft1636nm.htm#1433259
Ankur
*Pls rate all helpfull post
ankbhasi
Hi Friend,
The only way is define tha port as "switchport" and assign it to a vlan and then finally create layer 3 interface for that vlan.
But again that physical port is only a layer 2 port associated to layer 3 logical port.
Ankur
Thanks for your response. We would also need to get a switchport module for that, correct?
Hi Friend,
Ankur
