04-17-2014 03:40 AM - edited 03-07-2019 07:08 PM
Div1 (DW1, DW2), Div2 (DW3, DW4), Div3 (DW5, DW6)
I configured EIGRP as the routing protocol between core and distribution switches. there are static routes configured in core switches. I redistributed static routes in EIGRP.
In each distribution switch, I configured vlans and HSRP.
When I show ip route in DW1, it does not show static routes redistributed from core-1. And in DW2, it does not show static routes redistributed from core-2.
below is output from DW1:
show ip route
Gateway of last resort is 10.111.207.85 to network 0.0.0.0
D*EX 0.0.0.0/0 [170/3072] via 10.111.207.85, 6w2d, GigabitEthernet1/1/2
10.0.0.0/8 is variably subnetted, 36 subnets, 7 masks
D EX 10.0.0.0/8 [170/28416] via 10.111.207.85, 6w2d, GigabitEthernet1/1/2
C 10.111.200.0/24 is directly connected, Vlan200
L 10.111.200.2/32 is directly connected, Vlan200
C 10.111.201.0/24 is directly connected, Vlan210
L 10.111.201.2/32 is directly connected, Vlan210
D 10.111.202.0/24
[90/3328] via 10.111.207.85, 6w2d, GigabitEthernet1/1/2
[90/3328] via 10.111.207.81, 6w2d, GigabitEthernet1/1/1
D 10.111.203.0/24
sh ip eigrp topology 10.0.0.0/8
EIGRP-IPv4 Topology Entry for AS(100)/ID(192.168.50.2) for 10.0.0.0/8
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 28416
Descriptor Blocks:
10.111.207.85 (GigabitEthernet1/1/2), from 10.111.207.85, Send flag is 0x0
Composite metric is (28416/28160), route is External
Vector metric:
Minimum bandwidth is 100000 Kbit
Total delay is 110 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1500
Hop count is 1
External data:
Originating router is 192.168.50.3
AS number of route is 0
External protocol is Static, external metric is 0
Administrator tag is 0 (0x00000000)
My question is why static routes redistributed from core switches are not all appeared in DW1 or DW2? In other distribution switches, all static routes are advertised, but Originating router either 192.168.50.2 or 192.168.50.3 which are the vlan interface ip address of DW1 and DW2.
Please help me.
Solved! Go to Solution.
04-22-2014 09:32 AM
Can you passive-interface vlan 50 and vlan 1203 on DS1 and DS2? I will typically set passive interface as the default and only do no passive on the interfaces where I want EIGRP neighbor relationships to form. You don't need neighbors on every vlan interface.
Have you done any debugs? I think DS1 and DS2 might be sending summary routes for 10.0.0.0/8 to each other through these vlan interfaces. These summary routes will then be advertised to the upstream core switches. If you remove the vlan neighbor relationships, they won't summarize anything to each other since there's no network boundary to cross.
04-17-2014 10:19 AM
vlan 270
interface GigabitEthernet3/13
no switchport
ip address 10.111.207.81 255.255.255.252
auto qos voip trust
service-policy input AutoQos-VoIP-Input-Dscp-Policy
service-policy output AutoQos-VoIP-Output-Policy
interface GigabitEthernet3/15
no switchport
ip address 10.111.207.89 255.255.255.252
auto qos voip trust
interface GigabitEthernet3/25
no switchport
ip address 10.111.207.97 255.255.255.252
interface GigabitEthernet3/27
no switchport
ip address 10.111.207.105 255.255.255.252
interface GigabitEthernet3/47
switchport trunk allowed vlan 270
switchport mode trunk
channel-group 1 mode desirable
interface GigabitEthernet3/48
interface GigabitEthernet5/45
no switchport
ip address 10.111.207.41 255.255.255.252
speed 100
duplex full
interface Vlan1
no ip address
interface Vlan270
ip address 10.111.207.2 255.255.255.240
standby ip 10.111.207.1
standby priority 105
standby preempt
router eigrp 100
network 10.111.207.0 0.0.0.15
network 10.111.207.16 0.0.0.3
network 10.111.207.20 0.0.0.3
network 10.111.207.64 0.0.0.31
network 10.111.207.96 0.0.0.15
no auto-summary
redistribute static
ip route 0.0.0.0 0.0.0.0 10.111.207.4
ip route 10.0.0.0 255.0.0.0 10.111.207.42
ip route 10.0.0.0 255.0.0.0 10.111.207.3 10
04-17-2014 11:03 AM
So D3 and D4 are correctly getting the static routes?
04-18-2014 04:32 AM
Yes, they get two static routes as expected, but originating routers are DW1 and DW2 instead of core-1 and core-2.
04-17-2014 11:16 AM
What switch is the config above from ?
If it is one of the core switches then from DW1s IP routing table it is getting those routes.
Note that with the statics in the config above you have the same route twice but one has a higher AD so this would not be installed in the routing table and so would not be redistributed.
So if the config is from a core switch then DW1s routing table looks correct to me.
Perhaps you could clarify exactly what the issue is you are seeing.
Jon
04-18-2014 04:31 AM
yes, it is core-1 switch config.
I expected two equal distance static routes in DW1 and DW2, but they only has one static routes and the originating routers are each other. But for DW3-6, they have equal distance static routes, and originating routers are DW1 and DW2 instead of core-1 and core-2.
04-18-2014 04:39 AM
It's really not clear what you mean.
When you say you expect equal distance static routes do you mean each core switch is redistributing those static routes into EIGRP ?
If so are the links the same speed from DW1 and DW2 to both core switches ?
Are you doing any redistribution of statics on any of the DW switches ?
Jon
04-18-2014 10:16 AM
Yes, each core switch is redistributing their static routes to EIGRP.
the link speeds are the same.
there are no static routes configured in DW switches nor redistribute static routes.
following is partial config for DW1.
DW1(other DW switch configs are about the same.)
vlan 50
vlan 200
vlan 210
interface Port-channel1
switchport trunk allowed vlan 50,200,210,260,1203
interface GigabitEthernet1/1/1
no switchport
ip address 10.111.207.82 255.255.255.252
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust device cisco-phone
mls qos trust dscp
auto qos voip cisco-phone
service-policy input AutoQoS-Police-CiscoPhone
interface GigabitEthernet1/1/2
no switchport
ip address 10.111.207.86 255.255.255.252
queue-set 2
priority-queue out
mls qos trust dscp
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface Vlan50
description OA_GUEST
ip address 192.168.50.2 255.255.255.0
ip helper-address 10.111.205.143
standby 50 ip 192.168.50.1
standby 50 priority 105
standby 50 preempt
interface Vlan200
description OA_DATA
ip address 10.111.200.2 255.255.255.0
standby 200 ip 10.111.200.1
standby 200 priority 105
standby 200 preempt
interface Vlan210
description OA_VOICE
ip address 10.111.201.2 255.255.255.0
standby 201 ip 10.111.201.1
standby 201 priority 105
standby 201 preempt
router eigrp 100
network 10.111.200.0 0.0.0.255
network 10.111.201.0 0.0.0.255
network 10.111.207.80 0.0.0.3
network 10.111.207.84 0.0.0.3
network 192.168.50.0
eigrp stub connected summary
core1(core2's config is identical)
vlan 270
no switchport
auto qos voip trust
no switchport
auto qos voip trust
no switchport
no switchport
no switchport
speed 100
duplex full
interface Vlan1
no ip address
interface Vlan270
standby preempt
router eigrp 100
no auto-summary
redistribute static
04-18-2014 12:53 PM
what are these next hops ie. which switches or other L3 devices.
I think we can only get to the bottom of this if we know all the IPs.
Jon
04-21-2014 03:22 AM
Thanks Jon for your prompt replies.
ip route 0.0.0.0 0.0.0.0 10.111.207.4 - this is Cisco ASA connected to ISP
ip route 10.0.0.0 255.0.0.0 10.111.207.42 - this is Cisco router for MPLS.
ip route 10.0.0.0 255.0.0.0 10.111.207.3 10 - this is core-2 switch.
04-21-2014 04:18 AM
How are the ASA and core MPLS router connected to the core switches. Are they dual honed to both core switches ?
Can you from each DS switch post a -
"sh ip eigrp topology <network/mask> all-links"
for both the routes.
You can post the outputs into a file and attach it to the post to keep the thread manageable but don't worry if not, just post into the thread.
Also you say DSW3/4 are showing all routes but with DSW1/2 as the originating routers.
What happens if you do a traceroute to the core MPLS router from DSW3. Does it go to one of the core switches and then to the MPLS router ?
Finally i am assuming the schematic you provided is complete ie. there are no other connections between the DSW switches other than to the core switches ?
Jon
04-21-2014 06:45 AM
We have two ASAs, one ASA(Active) is connected to core-1 and the other ASA(standby) is connected to core-2.
We have one MPLS router. one of the interfaces is connected to core-1, and another interface is connected to core-2.
I have attached the output of "sh ip eigrp topology all-links" and sh ip eigrp topology 0.0.0.0/0 and 10.0.0.0/8".
If I traceroute to the MPLS router, below is the output. it goes to core switches. 10.111.207.65 and 69 is core switch interface IPs.
traceroute 10.111.207.42
Tracing the route to 10.111.207.42
1 10.111.207.65 0 msec
10.111.207.69 0 msec
10.111.207.65 8 msec
2 * * *
3 * * *
4 * * *
5 *
CCR-3750X-1#ping 10.111.207.42
Sending 5, 100-byte ICMP Echos to 10.111.207.42, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/8 ms
There are no connections between DSW groups, but connections within the groups. ie. DSW1 <-> DSW2, DSW3 <->DSW4, DSW5 <-> DSW6
Paul
04-21-2014 07:26 AM
Paul
Thanks for the additional information.
However i cannot read your attachements. I have downloaded a unzip utility and it still won't read them.
Not sure how to open them but could you not save them simply as text files and then zip that up ?
Edit - okay i just needed to add a suffix to the files. I can read them now.
Jon
04-21-2014 07:44 AM
Paul
Just in case you didn't see the edit i can read the files now.
Jon
04-21-2014 07:46 AM
DSW1/2 are only seeing the one route even in the full topology table.
So if you do a "sh ip eigrp neigh" on those switches do you see a neighborship with each core switch ?
Compare the same with DSW3/4.
Jon
