High CPU catalys 6500
raulalejandroortegameza
Community Member
Hi people I have a questions about catalys 6500
In the picture, what is the process with most consumed?
total is 77%, but all process are 0.xx and 1.xx.  I don´t understand that, because should be higher or not?
Thank very much
Leo Laohoo
What IOS are you running?
it´s this
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICES_WAN-M), Version 12.2(33)SXJ3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 16-Apr-12 16:12 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
 SW_SCL_DTC_MC01_02 uptime is 7 weeks, 6 days, 3 minutes
Uptime for this control processor is 7 weeks, 6 days, 2 minutes
Time since SW_SCL_DTC_MC01_02 switched to active is 7 weeks, 6 days, 1 minute
System returned to ROM by reload at 15:14:37 CLT Wed Feb 26 2014 (SP by reload)
System image file is "sup-bootflash:s72033-ipservices_wan-mz.122-33.SXJ3.bin"
Last reload reason: Reload Command
cisco WS-C6506-E (R7000) processor (revision 1.1) with 983008K/65536K bytes of memory.
Processor board ID SAL10478QP7
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
17 Virtual Ethernet interfaces
147 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
ansverma
CPU is high due to interrupts, means traffic is hitting the CPU, which is not normal. because catalyst switches are capable enough to forward traffic in h/w only. It is 6k so its easy to find the source of traffic/kind of traffic hitting CPU. We can use NetDr tool to troubleshoot this. NetDr tool is IOS inbuilt tool to captures traffic before it hits CPU.
6500-2#debug netdr cap
wait for couple of seconds.
6500-2#sh netdr cap
It will give you a long output. you check that and if majority of traffic is coming from a single source then you might need to track it and shut down that machine/user.
You can show the output here in case you need.
Anshul
Thank for your answer  Ansverma
I could to identify traffic with most consumed. It's a flow between two servers, the data are more than 1Gbps, but the interface is only Gi,
the problem is only in the afternoon, 1 hour approx
in the picture you can to see the diagram with scenery. also it's necesary to mention  that servers are in the same vlan, but in diferent subnet, because they are secundary IP.
if I configure an etherchannel to increase the speed between  both CORE, Could lower the high CPU?
Thank very much
