EIGRP Summarization
inaiate87
Frequent Visitor
Frequent Visitor
hi friends,
In EIGRP, is it possible to configure a summary route from an AS into an interface connected to a different AS?
Thnks in advance
I believe that it is not possible because different AS in EIGRP do not share/exchange routing information between them by default. The only way how to get such information from one AS to another is to configure redistribution.
http://www.cisco.com/c/en/us/support/docs/ip/enhanced-interior-gateway-routing-protocol-eigrp/16406-eigrp-toc.html#twoeigrpauto
As Paul correctly pointed out, the manual summarization is configured using the command: ip summary-address eigrp as-number network-address subnet-mask [admin-distance]
You see, there's the as-number parameter which defines the actual AS we want to perform summarization in, so unless the network you want to summarize is included in both AS (most likely due to AS redistribution in EIGRP) it will not work.
Best regards,
Jan
5 Replies 5
Hello
Eigrp summarization is defined at an interface level towards your eigrp peers
int xx
ip summary-address eigrp (as) xxxx.xxxxx
res
Paul
Kind Regards
Paul
Hi Paul,
my doubt is if I have a scenario where a have RouterA with one interface in AS1 and another in AS2, if a define a summary for AS1 in the interface connected to AS2 will it work?
Best regards,
Jan
Thanks Jan
Jan Hrnko
Level 9
Level 9
