Embedded Packet Capture for a Cisco 4500X switch
rakuten02
It seems that capturing on physical interfaces configured as L2 does not capture any IP traffic packets. It only captures STP and VRRP traffic etc.
However, if I capture based on the vlans instead, I can see IP data traffic being captured, but capturing based on vlans will result in vlan traffic of the entire switch being captured and not a specific interface.
How do I determine the source interface from vlan based embedded packet capture?
monitor capture capx interface TenGigabitEthernet1/1/1 both
monitor capture capx vlan 100,403-304 both
monitor capture capx access-list ACL1
monitor capture capx file location bootflash:capx.pcap
Note that I can in fact use any physical interface for the first line and it will still work.. so it does not prove that the captured traffic comes from that interface.
5 Replies 5
Hello @rakuten02
 Take a look on this  guide:
https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-embedded-packet-capture/116045-productconfig-epc-00.html
You may need to mark your traffic of interest
ip access-list extended BUF-FILTER
permit ip host 192.168.1.1 host 172.16.1.1
permit ip host 172.16.1.1 host 192.168.1.1
monitor capture buffer BUF filter access-list BUF-FILTER
Hi Flavio, I have already used an ACL to filter the logs.
The command you listed appears to be for IOS instead of IOS-XE.
what you need to capture here ?
MHM
I am trying to capture TCP traffic between 2 IP addresses. I have used an ACL to filter  the logs to only those 2 IPs.
Use this
Monitor capture point MHM interface x/x filter ip protocol tcp src <><> dest-port 80 associate file bootflash:MHM.pcap
Monitor capture point MHM start
Monitor capture point MHM stop
Show monitor capture file bootflash:MHM.pcap
MHM
