Enable C9200L-24T-4X routing
Electronic20
Hi Community,
Tengo 2 switch C9200L-24T-4X en stack, estos son sus datos:
Version IOS:
Switch Ports Model SW Version SW Image Mode
* 1 28 C9200L-24T-4X 17.03.04b CAT9K_LITE_IOSXE INSTALL
2 28 C9200L-24T-4X 17.03.04b CAT9K_LITE_IOSXE INSTALL
Licenses:
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-essentials Smart License network-essentials
dna-essentials Subscription Smart License dna-essentials
License Usage:
License Entitlement Tag Count Status
network-essentials (C9200L-NW-E-24) 2 IN USE
dna-essentials (C9200L-DNA-E-24) 2 IN USE
With this version of IOS and license, would it be possible to configure dynamic routing protocols: OSPF, EIGRP, BGP, IS-IS?
If it were not possible to configure dynamic routing, what would be needed to activate dynamic routing for OSPF, EIGRP, BGP, IS-IS?
regards
Electronic20
7 Replies 7
@Electronic20
 Yes, with network essencial you should be able to routing. Enable it with the command "ip routing"
Hi @Flavio Miranda
we also have this model of switch C9300-24T-E and these are the details:
With this information, it is not necessary to enable a license to configure dynamic routing protocols OSPF, BGP, EIGR, IS-IS?
regars
Electronica20
If you are planning on using full OSPF, BGP. ISIS, etc., you need the network advantage license. See link:
https://www.cisco.com/c/dam/m/en_us/products/software/dna-subscription-switching/en-sw-sub-matrix-switching/pdf/c95-742566-sw-sub-matrix-switching.pdf
Hi @Reza Sharifi
Thanks for the information.
The network advantage license is applicable for both switches: C9300-24T-E and C9200L-24T-4X?
To configure IP SLA, is a license also needed on both switch models?
regards
Electronic20
DNA Essentias is not enough. You need to have at least network essentials. The print you paste above only shows DNA Essentials
Electronic20
Hi @Flavio Miranda
Review both switches in more detail:
 C9200L-24T-4X
C9300-24T-E
If you have the network essentials, but I understand that it would not support BGP, IS-IS, EIGRP, but with that license would it support ip sla?
regards
Electronica20
@Electronic20
  IP SLA and BGP you need Network advantage.  You can check this by yourself on the Data Sheet document.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.htm
