Bookmark
Subscribe
8220
Enable LLDP on Cisco 3750
btedeschi
Need to enable LLDP on a 3750 switch, but command will not take and receive, "invalid input detected". Reason LLDP needs to be turned is for 4 Meraki MR34 access points. MR34 is running in low power mode and Meraki support suggested enabling LLDP (lldp run from confg t mode), but it is not working. Also tried to enable LLDP on individual interfaces, but those commands will not work either. That is as far as Meraki will take it so hoping this support community can help. 3750 is running IOS version c3750-ipservicesk9-mz.122-25.SEE4.
According to 3750 switch Power for the MR34s is 15.4W
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Fa1/0/1   auto   off        0.0     n/a                 n/a   15.4
Fa1/0/2   auto   off        0.0     n/a                 n/a   15.4
Fa1/0/3   auto   on         15.4    MR34                4     15.4
Fa1/0/4   auto   on         15.4    MR34                4     15.4
Fa1/0/5   auto   on         15.4    MR34                4     15.4
According to Meraki dashboard power consumption
9.34 W PoE 802.3af (running in low power mode)
Thanks in advance for any help provided.
Brett
2 Accepted Solutions
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Believe you need a newer IOS version for LLDP support.  (As Cisco has had CDP, they're a bit late supporting LLDP.)
Have a look at Table 6 of the c3750 12.2(46)SE Release Notes:
Link Layer Discovery Protocol (LLDP) and LLDP Media Endpoint Discovery (LLDP-MED: 12.2(37)SE
Link Layer Discovery Protocol Media Extensions (LLDP-MED): 12.2(40)SE
Rolf
Joseph W. Doherty
Disclaimer
Posting
Rolf
