Enable SNMP3 on Nexsus 5548
olsonkyle12
I'm trying to enable SNMPv3 on my Nexuss 5548.
On my 2960 and 4900, I was able to use the commands below and snmpv3 works great.  How can I duplicate the configuration on my Nexuss 5548 so that it matches the config on my 2960.  It does not appear that I can add a snmp group name to 5548, or at least the command line syntax is not the same.
snmp-server group Cisco v3 priv
snmp-server user administrator Cisco v3 auth md5 seea11over! priv aes 128 seea11over#
SunilKhanna
Hello Kyle,
NX-OS works differently than IOS. Here is the URL for configuring SNMP on a Nexus 5000 series switch
Cisco Nexus 5000 Series NX-OS System Management Configuration Guide, Release 5.0(3)N1(1)
Hope the URL helps you in achieving the task.
Sunil.
Pls rate the post, if you find the content helpful.
Regards, Sunil Khanna
