Diffrence between 4510R-E and 4510R+E
syamkumar123123
Community Member
can any one tell
what is the diffrence b/w 4510R-E and 4510R+E
where the 4510R-E is costlier than 4510+E  and 4510R-E supports only24 GB per line card where as 4510R+E supports 48GBps with sup 7 E
6 Replies 6
IAN WHITMORE
Level 9
Level 9
You can see all the differences here:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/product_data_sheet0900aecd801792b1.html
Ian
Please rate if I helped.
I THINK YOU HADN'T UNDERSTAND MY QUESTION I HAD GONE THROUGH THIS DATA SHEET 10 TIMES BEFORE I POST THE DISCUSSION .IF LOOK AT FEATURES THE 4510R+E HAVING MORE THAN 4510R-E BUT THE 4510R-E IS COSTLIER THAN 4510+E WHY THIS ? THERE ANY OTHER FEATURE EXTRA WHICH IS NOT MENTIONED IN DATA SHEET FOR 4510-R
agugger
Level 3
Level 3
This price changes has no technical or feature relations.
The 45XXRplus chassis can more for a better price than 45XXminus chassis.
Cisco follows a long time criticized point from customers. The following price politic was not understandable, except to place the 6500 series in better position.
If you get for 4506 Chassis a price of 100%, cost the 4507R chassis 200% or the same as two 4506 chassis.
This only for one slot more and you need still a second supervisor for a useful application.
And the 4510R chassis cost so 250% of a C4506 chassis.
So the actual prices relations are now a little better.
Andy
kclimie
Frequent Visitor
Frequent Visitor
It took me a while to find it too.  The difference is that the capacity to each slot is increased from 6 Gbps and 24 Gbps per line-card on the 4510R-E to 6Gbps, 24Gbps, or 48Gbps per line-card in the 4510R+E.
Hope that helps.
See the below difference in its specifications.
4510R+E specifications:
And 4510R-E supports only classic line cards in slots 8 to 10 with Supervisor Engine 6-E.
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps9294/product_data_sheet0900aecd806df543_ps4324_Products_Data_Sheet.html
Please rate the helpfull posts.
Naidu.
