Enable static route between two Vlans on C2960S
Not applicable
Dear All
I have a C2960S stack with 3 stack members. I have configured two vlans namely vlan1 and vlan2.
vlan1 having interface 172.16.2.11 255.255.0.0
vlan2 having interface 192.168.1.22 255.255.255.0
(Please note that these two vlans have different subnets also)
I have enabled static routing by giving "ip routing" command
I want to configure static route between the two vlans.
Here we have the iOS version & details
Switch#sh version
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.0(2)SE10a, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Thu 03-Nov-16 13:52 by prod_rel_team
ROM: Bootstrap program is C2960S board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(55r)SE, RELEASE SOFTWARE (fc1)
Switch uptime is 1 week, 1 day, 2 hours, 11 minutes
System image file is "flash:/c2960s-universalk9-mz.150-2.SE10a/c2960s-universalk9-mz.150-2.SE10a.bin"
Any help is much appreciated.
Best Regards,
Amit Datekar.
Reza Sharifi
Since the 2 vlans (1 and 2) are configured on the same switch and IP routing is enabled, there is no need for static route. Just make sure both vlans are in up and up mode "sh ip int bri vlan1" and 2 if all good, try pinging both vlans while connected to the switch.
Just a note that the 2960s series switches are mainly layer-2.
