Bookmark
Subscribe
1029
Enable storm control in etherchannel
ivanka_busta
While upgrading the IOS of a Cisco WS-C6506-E from version 122-33.SXH4 to 122-33.SXJ10. I encountered the following issue:
Ports 2/8 and 2/42 are configured in a port-channel which is connected to a cisco WS-CBS3012-IBM-I.
The configuration of these ports before upgrading was:
interface GigabitEthernet2/8
switchport
switchport trunk native vlan 20
switchport trunk allowed vlan 1,20,68,69,80-85,90,91,101,102,150,151,199
switchport mode trunk
storm-control broadcast level 5.00
channel-group 12 mode on
interface GigabitEthernet2/42
switchport
interface Port-channel12
switchport
spanning-tree vlan 1,20,68-69,80,82,84-85,90,199,222 port-priority 16
However, after reloading the switch to upgrade the IOS, the ports weren't added to Port-channel12. There was an error saying: storm control config doesn't match. Nothing had been changed in the  WS-CBS3012-IBM-I. The problem was solved deleting the storm-control command. I don't understand the reason of this problem with the command storm control.
The configuration of the WS-CBS3012-IBM-I was the same before and after upgrading the IOS of the  WS-C6506-E:
interface GigabitEthernet0/15
interface GigabitEthernet0/16
link state group 1 upstream
spanning-tree vlan 1,20,68-69,80-85,90,199,222 port-priority 16
end
Any ideas why this happened?
Thanks in advance.
Reza Sharifi
Have you tried applying the storm control config to the Portchannel (not the physical interfaces)?
switchport
switchport
switchport
Thanks for the suggestion. I'll give it a try.
