enabling lldp
suthomas1
Level 7
Level 7
Does lldp support on cisco switches depend on version.
We have a 3560-48PS, running 12.3.
It does not allow using lldp run to be used.
Please advise. Thank you.
Just adding another query , is it possible to increase the poe delivered on specific ports if the unused ones are disabled from using inline power.
will upgrading the version to support lldp also allow the poe to be higher than the current 802.af?
Or is the actual power imparted limited to the switch & independent of software.
No, the POE is part of the hardware. Software can't change that.
9 Replies 9
Reza Sharifi
It should not matter what version you are running.
config t
lldp run
should work fine.
What is error message you are getting?
No, depending on the module, there is a limited amount of wattage (poe 30w, upoe 60w) that is assigned to each port. You can't go above that number.
Thank you. The option is not presented, as below.
SW(config)#lld
SW(config)#lld?
% Unrecognized command
SW(config)#lld
on the poe aspect, i have turned off poe on some ports. This is to see if some of the devices, requiring more power than usual 15w, will get them.
Will upgrading the IOS help to allow lldp feature & in-turn increase the poe power delivery or is it strictly based on the switch model?
Can you post the result of the following command :
show version
Hello
Sh sdm prefer?
res
Paul
Kind Regards
Paul
Outputs for both sh ver & sh sdm prefer are given below.
Appreciate all inputs.
SW#sh ver
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 18:15 by nachen
Image text-base: 0x00003000, data-base: 0x01100000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
SW uptime is 2 weeks, 2 days, 4 hours, 30 minutes
System restarted at 14:35:24
System image file is "flash:c3560-ipbase-mz.122-35.SE5/c3560-ipbase-mz.122-35.SE5.bin"
cisco WS-C3560-48PS (PowerPC405) processor (revision P0) with 122880K/8184K bytes of memory.
Processor board ID FDO1237X1Z2
Last reset from power-on
2 Virtual Ethernet interfaces
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:12:C7:0B:4D:00
Motherboard assembly number : 72-9767-14
Power supply part number : 342-0020-06
Motherboard serial number : FDO12291Z2V
Power supply serial number : LIT12206L61
Model revision number : P0
Motherboard revision number : A0
Model number : WS-C3560-48PS-S
System serial number : FDO1237X1Z2
SFP Module assembly part number : 72-6657-02
SFP Module revision Number : A0
SFP Module serial number : FDO121901Z3
Top Assembly Part Number : 700-15864-02
Top Assembly Revision Number : A0
Version ID : V05
CLEI Code Number : CONU2110RA
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 52 WS-C3560-48PS 12.2(35)SE5 C3560-IPBASE-M
Configuration register is 0xF
SW#sh sdm prefer
The current template is "desktop default" template.
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1024 VLANs.
number of unicast mac addresses: 6K
number of IPv4 IGMP groups + multicast routes: 1K
number of IPv4 unicast routes: 8K
number of directly-connected IPv4 hosts: 6K
number of indirect IPv4 routes: 2K
number of IPv4 policy based routing aces: 0
number of IPv4/MAC qos aces: 0.5K
number of IPv4/MAC security aces: 1K
Hi!
The version you are running is not supported and you must have at least 12.2(55)SE to run lldp. See this Link:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_55_se/release/notes/OL23054.html
/Mohammed
Thanks, will upgrading the version to support lldp also allow the poe to be higher than the current 802.af?
