IPX tunnel over IP
tunemore1
Need sample config for IPX tunnel over IP (two IPX LAN connected with IP only link).
Harold Ritter
It can be as simple as configuring a GRE tunnel and applying an IPX address on it as follow:
interface Tunnel0
no ip address
ipx network deadbeef
tunnel source xyz
tunnel destination abc
Make sure you include this address under your routing protocol.
Hope this helps,
Harold Ritter
interface Tunnel0
no ip address
tunnel source xyz
Hope this helps,
Thanks. Do you know a good link about it on Cisco site?
I found the attached file in PDF format.
Hope this helps,
Please tell me some example Cisco router that will accept Harold Ritter's solution.  I'd like to use two RV340 routers, in a North American (California) incarnation.     IPX tunnel via IP.      Simple point-to-point job.       Thanks.
