Enabling Logging on an ASR from a source port
I have a Cisco ASR 1001.  I am trying to send traffic from g0 to a switch that picks up all my logging traffic.
Below is my config.  What am I missing.  I am trying to send traffic to device 10.10.23.17. I want to make sure that ll traffic get to 10.10.23.17.
Thanks in advance!
logging trap debugging
logging facility local1
logging host 10.10.23.17
ip route vrf Mgmt-intf 0.0.0.0 0.0.0.0 10.10.88.1
11 Replies 11
Collin Clark
Can you ping the syslog server from the management IP?
ping vrf Mgmt-intf 10.10.23.17
Syslog logging: enabled (0 messages dropped, 11 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: disabled
    Monitor logging: disabled
    Buffer logging:  disabled, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level debugging, 553 message lines logged
        Logging to 10.10.23.17  (udp port 514, audit disabled,
              link up),
              121 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
        Logging to 10.10.89.74  (udp port 514, audit disabled,
              link up),
              2 message lines logged,
              filtering disabled
        Logging Source-Interface:       VRF Name:
        GigabitEthernet0                Mgmt-intf
Thanks. Messages are being sent so that part looks OK. Is there a reason you're logging at facility local1?
Yes I am.
Can you post the results of a show log? Just the part up to the actual log entries.
Collin Clark
Good catch Rolf. This is IOS-XE so the command is a little different.
logging source-interface GigabitEthernet0 vrf Mgmt-intf
Thanks Collin. Those little differences make our life much more interesting, right? ;-)
ThinMan
Hi All,
I have the same issue too. so I am trying to configure syslog via management interface.
1. I can ping the Syslog server via management interface
2. I have the below config
logging host 10.x.x.x vrf Mgmt-intf
3. I see the below for show logging but none received in Syslog server
Oct 9 07:08:42.485: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.x.x.x port 514 (Mgmt-intf) started - reconnection
*Oct 9 07:10:52.529: %SYS-5-CONFIG_I: Configured from console by admin on vty0 (10.2.3.1)
 I have a same issue. However, I found an interesting stuff. After the configuration, I was able to see syslogs from Solarwind Orion, but not from Kiwi syslog server (I am pulling to two servers). If you don't see any log shipped from the ASR, try it to a different server (or app) to make sure you can see the log. I believe each syslog server has own syslog format to accept. If you don't have additional app, just do packet capture to confirm it.
Thanks Kyujin. I actually figured out the issue, it was the syslog server that wasnt processing the logs. Like you mentioned, I had do a packet capture. so for me above configuration actually worked!
