enabling ssh ion 2970 swicth
bapatsubodh
How to enable ssh on 2950 with cisco IOS software C2970 ( C2950-LANBASE-M) Version - 12.2(25) SEB4.
I tried with crypro key generate rsa command. but it seems command is not supported. On this version of IOS.
Any link on Cisco.com
Thanks in advance
Subodh
skivergeo
Use AAA with TACACS or Radius or local auth.
glen.grant
Use "crypto key generate rsa modulus . You insert the length of the modulus key . Also you have to make sure you have the crypto version of code and by just looking at it it does not look like you do. Upgrade to crypto code to use SSH.
