Encryption between two routers found in the same IP-Range (why is this configuration not working ?)
Tenek85466
Router 1
Building configuration...
Current configuration : 1373 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname test
ip dhcp pool vlan30
network 192.168.30.0 255.255.255.0
default-router 192.168.30.254
dns-server 192.168.134.8
ip cef
no ipv6 cef
crypto isakmp policy 10
hash md5
crypto isakmp key 01.020r address 192.168.133.44
crypto ipsec transform-set 01.020r esp-des esp-md5-hmac
crypto map 01.020r 10 ipsec-isakmp
set peer 192.168.133.44
set transform-set 01.020r
match address 100
ip ssh time-out 60
ip domain-name test.com
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 192.168.30.254 255.255.255.0
ip nat inside
interface FastEthernet0/1
ip address 192.168.133.17 255.255.255.0
ip nat outside
duplex auto
speed auto
crypto map 01.020r
interface Vlan1
no ip address
shutdown
ip nat pool 01.020r 192.168.133.17 192.168.133.17 netmask 255.255.255.0
ip nat inside source list 10 pool 01.020r overload
ip classless
ip flow-export version 9
access-list 10 permit 192.168.30.0 0.0.0.255
access-list 100 permit ip 192.168.30.0 0.0.0.255 192.168.30.0 0.0.0.255
banner motd ^C
ex
^C
line con 0
line aux 0
line vty 0 4
login
end
test#
test con0 is now available
Press RETURN to get started.
ex
test>
test>
test>
test>en
test#conf t
Enter configuration commands, one per line. End with CNTL/Z.
test(config)#
test(config)#
test(config)#ex
test#
%SYS-5-CONFIG_I: Configured from console by console
test#
test#sh
test#sh ru
test#sh running-config
version 12.4
hostname test
ip dhcp pool vlan30
ip cef
no ipv6 cef
hash md5
match address 100
ip ssh time-out 60
no ip address
duplex auto
speed auto
ip nat inside
ip nat outside
duplex auto
speed auto
crypto map 01.020r
interface Vlan1
no ip address
shutdown
ip classless
banner motd ^C
ex
^C
line con 0
line aux 0
line vty 0 4
login
end
Router 2
Current configuration : 1338 bytes
version 12.4
hostname Router
ip dhcp pool vlan30
ip cef
no ipv6 cef
hash md5
authentication pre-share
crypto isakmp key 06.010r address 192.168.133.17
crypto ipsec transform-set 06.010r esp-des esp-md5-hmac
crypto map 06.010r 10 ipsec-isakmp
set peer 192.168.133.17
set transform-set 06.010r
match address 100
no ip address
duplex auto
speed auto
ip nat inside
ip address 192.168.133.44 255.255.255.0
ip nat outside
duplex auto
speed auto
crypto map 06.010r
interface Vlan1
no ip address
shutdown
ip nat pool 06.010r 192.168.133.44 192.168.133.44 netmask 255.255.255.0
ip nat inside source list 10 pool 06.010r overload
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Router#
Router con0 is now available
Router>
Router>
Router>
Router>
Router>en
Router#sh ru
Router#sh running-config
version 12.4
hostname Router
ip dhcp pool vlan30
ip cef
no ipv6 cef
hash md5
match address 100
no ip address
duplex auto
speed auto
ip nat inside
ip nat outside
duplex auto
speed auto
crypto map 06.010r
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Best Regards
5 Replies 5
Deepak Kumar
It seems that a subnet 192.168.30.0/24 is overlapping at both sides. So you need NATing as an extra configuration.
You can guide a detailed guide here:
https://www.cisco.com/c/en/us/support/docs/routers/3800-series-integrated-services-routers/107992-IOSRouter-overlapping.html
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
did you not have this same issue resolved a few days ago ? You said you had configured twice NAT on one side, I don't see that in any of the configs you have posted ?
Hey @Georg Pauwen the issue is not yet resolved. NAT was configured on both Routers. I d'ont really get it when you say "configuring twice NAT on one side" Can you please explain ? Based on the Network diagram ?
Share your lab in the attachments.
Deepak Kumar,
My Lab as pkt file
