Limit Management Interface VLAN On Switch NEXUS 3000
Hi Dear Friends I define ACL 2
In VLAN Management
interface Vlan2
no shutdown
ip access-group 2 in
ip access-group 2 out
ACL Not Apply on inteface vlan and Have ping or ssh Access
Deepak Kumar
You can apply the ACL under the line vty such as:
ip access-list ABC
10 deny ip 172.18.217.82/32 any
20 permit ip any any
ip access-list XYZ
10 permit ip 10.55.144.118/32 any
20 permit ip 172.18.217.79/32 any
30 permit ip 172.18.217.82/32 any
40 permit ip 172.18.217.92/32 any
line vty
access-class ABC in
access-class XYZ o
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
try the below, if it doesn't work, post the full running config of your Nexus...
interface Vlan2
ip access-group BLOCK_ICMP_SSH in
ip access-list BLOCK_ICMP_SSH
10 deny icmp any any
20 deny tcp any any eq 22
30 permit ip any any
HI Dears I Config ACL 2
permit ip 192.168.0.0 0.0.0.255 any
permit ip any 192.168.0.0 0.0.0.255
deny ip any any
