Enhanced Object Tracking and 2960S LAN Base
l.buschi
Level 2
Level 2
HI all,
I have a 2960S with lan base IOS and default SDM set to lanbase routing.
Static routing is perfectly working.
I configured an icmp IP SLA checking a remote destination reachability.
I need to track into the SLA in order to configure a static route with object tracking.
The feature navigator confirm that 2960S can handle enhanced object tracking.
IP route commands support track-table statements but I have no way to configure an object connected to my IP SLA.
Do you know a way to do this?
Tks
Johnny
moThaSeb
I will be glad to know if you were able to fix the problem.
I'm running into exactly the same problem. I tried several IOS going from 12.2(53+) upto 15.2+ tracks without success.
In the later IOS's 15.0(2)S5 and upwards, even ip sla <number> disapeard.
Facing the issue with models WS-C2960S-48FPS-L and also WS-C2960S-48LPS-L.
Thanks for anyone's help.
I have the same problem  with WS-C2960S-48LPD-L
