EoMPLS functionality
Mary
Level 5
Level 5
we have use VPLS as our L2 extension, do we have to use EoMPLS as well, what's the benefit of EoMPLS?
Dmitri Popkov
Level 3
Level 3
It depend on your goal. EoMPLS is E-Line technology, so its just P2P L2 tunnel over mpls enabled network. VPLS is E-LAN technology, that simulates broadcast media over mpls enabled network and also builds MP2MP L2 tunnels
so EoMPLS is MetroE not DWDM?
Julio E. Moisa
EoMPLS basically is implemented when you are using sub-interfaces and dot1q. But it will works like point-to-point only, if you want point-to-multipoint VPLS could be a solution.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
