erase bootvar
saravanababu22
friends,
look into the below info
BOOT variable = ,1;s3223-entservicesk9_wan-mz.122-18.SXF8.bin,1;bootdisk:s3223-e
ntservicesk9_wan-mz.122-18.SXF8.bin,1;bootdisk:s3223-entservicesk9_wan-mz.122-18
.SXF8.bin,1;
CONFIG_FILE variable =
BOOTLDR variable does not exist
what does this "BOOT variable = ,1" refer to, how to clear this boot var statement. i need to point it to single image followed by 1.
i want the output to be configured as
MSFC(boot)# show boot
BOOT variable = s3223-entservicesk9_wan-mz.122-18.SXF8.bin,1
CONFIG_FILE variable does not exist
BOOTLDR variable = bootflash:s3223-entservicesk9_wan-mz.122-18.SXF8.bin
kindly guide me
Edison Ortiz
It's all part of the boot system command. Please refer to the documentation:
http://www.cisco.com/en/US/docs/ios/fundamentals/command/reference/cf_a1.html#wp1015403
HTH,
__
Edison.
Yudong Wu
Level 7
Level 7
"BOOT variable = ,1" refer to command "boot system flash".
Type "sh run | i boot system" to see what boot statement in the current config. And then remove unused boot command. Then "wr mem" and check "show boot" again.
ullasupendran
In your case remove the existing boot system commands and try the following one.
boot system flash:s3223-entservicesk9_wan-mz.122-18.SXF8.bin
boot system bootldr bootflash:s3223-entservicesk9_wan-mz.122-18.SXF8.bin
I assumed that the bootloader you mentioned in the output is correct.
Hope to help
Ullas
