erasing configuration from 6500
daveporter123
can any one help me to delet the startup and running configuration from the 6500 my switch is using cat os. i also want to know how can i get the various memory detail like amount of RAM FLASH and also about other supervisior engine?
dporter
glen.grant
If it strictly catos isuue the "clear config all" command . If it has a msfc card just log into the msfc and do a "write erase" command and reload the card . Use the show version " and the dir bootflash: command to get the flash sizes . If it has a pcmcia card do a dir slot0: or a dir disk0:
fzamora
All you need to do to clear everything is
do a clear config all on the CatOS, if you have a MSFC do a wr er (write erase).
When doing the MSFC3, you do the write erase, and will have to issue a reload. It will ask
you to save your config, and just type No, or "N".
Use the sho verion to get the other information you need, check below:
Console> show version
WS-C6009 Software, Version NmpSW: 6.2(0.11)KEY
Copyright (c) 1995-2000 by Cisco Systems
NMP S/W compiled on Oct 5 2000, 01:18:33
System Bootstrap Version: 5.2(1)
Hardware Version: 1.0 Model: WS-C6009 Serial #: SCA030900JA
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP1A-2GE SAD03392376 Hw : 1.0
Fw : 5.2(1)
Fw1: 5.1(1)CSX
Sw : 6.2(0.11)KEY
Sw1: 6.2(0.11)KEY
L3 Switching Engine SAD03365068 Hw: 1.0
3 2 WS-X6380-NAM JAB0343055Y Hw : 0.201
Fw : 4B4LZ0XA
Fw1: 4.2(0.24)DAY68
Sw : 1.1(0.20)
Sw1: 6.2(0.11)KEY
5 48 WS-X6248-RJ-45 SAD03181291 Hw : 1.0
Fw : 4.2(0.24)VAI78
Sw : 6.2(0.11)KEY
15 1 WS-F6K-MSFC SAD03366264 Hw : 1.2
Fw : 12.1(2)E,
Sw : 12.1(2)E,
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 65408K 45402K 20006K 16384K 8683K 7701K 512K 253K 259K
Uptime is 1 day, 19 hours, 54 minutes
Console> (enable)
More information at: http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_8_5/cmd_ref/sh_u_v.htm
Hope it helps,
Franco Zamora
