Errdisable Recovery-Best Practices?
Miss_Understood
I am re-configuring several switches on a small network.(catalyst 3750,3560) A previous employee configured the 3750 stack with all of the errdisable recovery options enabled, even for some items that we are not running like vmps. I am trying to decide what to do with these settings. I understand WHAT errdisable recovery does and WHY, but I don't understand WHEN to to allow automatic recovery and when not to. I have looked everywhere for Cisco's "Best Practices" on this subject but can't manage to track anything down. Any help would be appreciated!
Jason Fraioli
Level 3
Level 3
I enable auto recovery on my LAN, but I also send a trap when a port goes errdisable. That way I get a log/email.
I was looking at the same thing for basic switch best practices using err disable recovery. Here is what I found.
Try to minimize or refrain from using "errdisable recovery" option.  This is even more important when used on a chassis-based system like the 6500/6800 and/or 4500 systems. If the ports went into error-disable this means something is wrong and is worth investigating.  To use "errdisable recovery" is akin to sweeping a potential problem under the carpet and is not a good practice.  This option only works well in a lab environment
Hello
I personally wouldn’t errdisable recovery on BPDU-Guard or UDLD as I would want to investigate further as to why those ports errored in the first place.
BPDU-guard may mean you have end users unwittingly attaching unauthored switches to the network and you need to track them down
UDLD because if you do have a faulty port/module you wouldn’t want it to constantly flap maybe causing unwarranted stp recalculations and network re-convergence
Kind Regards
Paul
