Error when connecting to switch via serial port- hulc_sfp_iic_intf_read_eeprom sfp _index 3 yeti_iic_read_retry fail
EugeneS
Good Day
I have a couple of cisco catalyst 2960-x series switches in which one of them is giving an error when connecting via serial port it gives the below error. What could it be related to as i have issues now to configure SSH as the error keeps coming up line by line on each key entry preventing me to do any configs. Please give advise or should i reset to factory default settings and reconfigure the switch?
balaji.bandi
Look at the bug :CSCur56395
BB
I will surely schedule for downtime and give this a try it seems like it is best solution. I will give update
Giuseppe Larosa
Hello @EugeneS ,
under line con 0
use
logging synchronous
this should allow you to enter configuration commands without having the line mixed with the error messages
Edit:
try the workaround suggested by the bug listed in BB's answer if a power cycle can solve it is an easy action.
Hope to help
Giuseppe
thank you i will try this out and give update.
