error when try to make un uplink between IE 2000 and Catalyst 3560
nirbb
When I try to create an uplink between the above two switches through an SFP port, I get the following error on the IE 2000 switch
Where is the problem and what is not set correctly in the switches?
15 Replies 15
sorry my mistake
Security-SW7#show interfaces gigabitEthernet 1/1/1
GigabitEthernet1/1/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 70db.9818.a999 (bia 70db.9818.a999)
Description: Connected to Sec-sw5 interface fa1/9
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Security-SW7#show interfaces gigabitEthernet 1/1/2
GigabitEthernet1/1/2 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 70db.9818.a99a (bia 70db.9818.a99a)
Description: Connected to Sec-sw4 interface gi1/2
Keepalive not set
Auto-duplex, Auto-speed, link type is auto, media type is unknown
